A stall
Old Feb 11, 2009 | 12:43 AM
mikemunoz's Avatar
Default A stall
OK I KNOW THAT A STALL IS GOOD TO GET OFF THE LINE FASTER, BUT DOES IT HELP WHEN THE CAR IS GOING FOR EXAMPLE: IM GOING 45 OR ANY SPEED AND GUN IT DOES THE TORQUE CONVERTER DO ANYTHING OR HELP
Old Feb 11, 2009 | 04:10 AM
01ws666's Avatar
Yea it helps alot from a roll as well. My yank PT3800 flashes to 4500 rpm's eleminating the typical "dead spots" for the auto. Also with the convertors shift extension my rpm's never drop below 5k after shifts under WOT, keeping you closer to the power band...
Old Feb 11, 2009 | 06:45 AM
Circle-D's Avatar
O1ws666 is correct. A performance converter will help get the car in the power band, even if you are already moving. They are also about 15 LBS lighter, so less rotating mass for the motor - free HP.
Chris
Old Feb 11, 2009 | 10:38 AM
Brickyard's Avatar
Hmm, thats good to know, I didn't realize that aftermarket converters were lighter as well.
Old Feb 11, 2009 | 01:01 PM
CoolAid's Avatar
Do a search on "Shift Extension" or "Shift Differential"
I took the stock 12'' out last night and it is a TANK. The 9.5'' Circle D +4C I have is svelte compared to that pile. Naturally, it will hold less fluid as well so the weight drops there too.
Old Feb 11, 2009 | 01:14 PM
troopercar's Avatar
No other single modification will improve and wake up an A4 LS1 better than a good converter.
Well, maybe a procharger.
Old Feb 11, 2009 | 02:40 PM
9000th01ss's Avatar
Chris
Heres proof.
Top pic is a drained stock converter on a certified scale. This is AFTER draining 8 pounds of fluid out of it.
Bottom pic is a Circle-D 3c.
