FLT power levels?
beefed up. I'm just trying to get a rough idea what Level IV and V can handle
in hp & tq? I appreciate for anyones help since i never had a tranny rebuilt.
Thx.
Den
killer times with your setup. would you mind describing your setup. 11.08@121 is doing stuff right. I have been running 11.4x @ 120 w 1.55 60s. and just installed a new flt level 4 with an fti converter. no track times on new setup.
those times were at full weight with tsp heads cam package cam being 595/598,fast 92/92 unported,flt lvl4 with a pt4000 & 373 gears in the 10 bolt,with full bmr suspension on stock shocks & springs with the rear springs having 1 ring cut off..........
just put on a 85 mm lid & 85 mm mass air,got rid of the front & rear impact bars & rear seats,she should hit a 10.90 now if the 10 bolt holds up
glad to hear you finally got a flt trans,now you can push the go peddle comfortably with no worries & not wait for it to go bang, and sleep at night & know when you wake up you can do it all again with out having to drop the trans! lol.
