FMVB 4L80 guys
Old Feb 16, 2009 | 01:34 PM
trey04gto's Avatar
Default FMVB 4L80 guys
What is your part throttle shifting like? Any way to vacuum modulate the shift firmness? I mean at 2500 rpm when you shift is it just as firm as if you were 6500 WOT? Also just your opinions? Its either this or a damn expensive controller for me....
Old Feb 16, 2009 | 02:29 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Light throttle shift are firm depending on you converter. A high stall converter will dampen some of the firmness. At higher RPM the pump is putting out it max pressure. What do you consider expensive for controls?
