700r4 problem
Old Oct 13, 2003 | 07:03 PM
backyarder's Avatar
Default 700r4 problem
just rebuilt 700r4 only have manual 1st and reverse all others slipping. pressures are as follows at idle. p-80lbs r-130lbs n-80lbs od-80lbs d-80lbs 2-180lbs 1-180lbs in park at idle pulling tv gives 175lbs. other gear selection feels like severe slipping. if touch brake will not move even with rpm increase. thank you any help greatly appreciated
