TH350 swap, need a new driveshaft?
Old Feb 23, 2009 | 10:43 AM
Black94Z28's Avatar
Default TH350 swap, need a new driveshaft?
Do i need to have a driveshaft made or is there somewhere that makes one for 4th gens with the TH350?
Old Feb 23, 2009 | 10:57 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
If you run the long tail shaft, you can use a stock length driveshaft. Some of the sponsors offer aftermarket one though
Old Feb 23, 2009 | 11:10 AM
EvilStang's Avatar
STF Veteran
how long is the tail shaft? if it is a 6in then you will need to have a driveshaft made. if it is the 9 inch then you will be able to use the stock drive shaft.
Old Feb 23, 2009 | 11:18 AM
bjamick's Avatar
Well looks like im just to late. Yes the stock driveshaft will work as long as you have the 9" tailshaft.
Old Feb 23, 2009 | 11:50 AM
Black94Z28's Avatar
still have yet to pick up a trans, what cars can i find the 9 inch tailshaft trans out of?
I have a running th350 out of an old 72 LeMans parts car I picked up, but its a BOP housing
Old Feb 23, 2009 | 12:02 PM
9000th01ss's Avatar
Big cars like station wagons, etc.
They are very common in vans and trucks. Be sure you don't get a th350c which is a lock up th350. These came in early 80's vehicles.
You can use one, either convert it to non lock up with a non lock up pump, input and valve body mods. Or an expensive custom converter if you plan to go with a higher stall speed. Make sure it doesn't have the electrical connector in the pic attached.
Also going by my tape measure, the long th350 is 1/2" shorter than an LS1 4L60E FWIW.
