4L60E longevity questions - NON Fbody
1 - I have heard of both the Corvette Servo as well as the Sonnax servo. Would simply going to the Corvette servo be good enough, or would the nearly $90 more for the Sonnax servo be worth it?
2 - Would a shift kit help, or would a simple tune with the upgraded servo be enough?
3 - What is the best fluid to go with in these transmissions?
4 - Any other suggestions?
Thanks guys!!!
As far as trans fluid, i don't think it really matters.
I wanted to steer away from the shift kit for now if possible, just because I hear it takes 4-5 hours to install, and I won't really need it until I eventually start trailer'ing' my TA to say autox or road races....first I have to rebuild the motor of course, lol.
Or will reprogramming the PCM do basically the same thing as a shift kit by upping the pressure and shift points when that time comes? I know some people tune their Blazer's PCM's for a few extra hp/tq out of the ol 4.3L.
But I also drive around in 3rd gear most of the time. Only in the city and up hills. That'll help save your trans. Only use OD when you know you'll be on a flat road and be able to hit 55. 4th gears are weak so the less it shifts into it, the better. Also when you command 3rd it applys more pressure, reducing slippage, and shifting alittle firmer. GM does that because your supposed to tow in 3rd obviously.
My brother has a 94 S10 4wd 4.3 HO.also,he bought it with 207,000 miles, original drivetrain. Only thing we upgraded was the 1-2 shift spring like i did. No servo or anything, and somehow that truck managed to get to it's current mileage of 395,000. And that trucks been run hard. But maintenance helps.
If anything I'd pull the valve body out and change that little spring. From the factory they really slip the tc while locking in. Which I think i one of the weak links on the s-series trans. I know from 95-00? they had problems with the valve bodies. So the fix was to bore out the cylinder (if needed) and install a stiffer spring as I did. My borthers 94 was before the EC3 system, I think they called it. Which goes from 0-100% lock up. Theres proof right there that 0-100% lock up will prolong the life of the converter. Damn near 400k
