can i use a truck flexplate
Old Feb 27, 2009 | 10:00 PM
5_02ls1's Avatar
Default can i use a truck flexplate
as title says can i use a truck flexplate im using an 03 lm7 engine and wondering if theres any issues with the truck flexplate and the fbody trans and converter.....
Old Feb 28, 2009 | 04:46 PM
5_02ls1's Avatar
anybody?????
Old Mar 1, 2009 | 06:11 AM
forcd ind's Avatar
it kind of depends on which truck flexplate-i know the ones that used the 4l80e had a flat flywheel, with a spacer bet the crank & flywheel-this setup will also work with a 400, 350, etc trans
if the truck had a 4l60e, it may have the same flywheel as a pass car-it all depends on what the flywheel looks like
Old Mar 1, 2009 | 06:27 AM
StrokerAce03's Avatar
You'll be fine; the flexplates are interchangeable from car to truck.
Old Mar 1, 2009 | 01:50 PM
5_02ls1's Avatar
alright thanks....
