wtf 4l60e acting up!!!!!!
Old Feb 27, 2009 | 11:23 PM
jag81's Avatar
Default wtf 4l60e acting up!!!!!!
well a while back i lost 3rd and 4th gear so i figured that it was the 3-4 clutch pack went out. well i was driving it the other day and i some how got all my gears back!!! then lost them about 10 minutes later... then tonight i was driving around and it was there for about a minute and gone and now it came back so i stopped driving it. wat should i look for or do???????
Old Feb 27, 2009 | 11:40 PM
performabuilt's Avatar
LS1Tech Sponsor
Use a scanner to see what the PCM is actually doing
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 27, 2009 | 11:45 PM
jag81's Avatar
thats the prob i dnt have a scanner or know any one with one
Old Feb 27, 2009 | 11:54 PM
LS1Tech Sponsor
Most any trans shop will have one and most regular garages
__________________
Call 888-744-6542
Old Feb 28, 2009 | 12:04 AM
jag81's Avatar
ok well im just gona buy one
Old Feb 28, 2009 | 08:25 AM
382ssz28's Avatar
If you are going to play with the car, invest in HP Tuners, LS-1 Edit, etc. You can tune as well as scan for codes and problems.
Old Feb 28, 2009 | 11:42 AM
jag81's Avatar
will a predator do codes?
Old Feb 28, 2009 | 11:47 AM
gymratt's Avatar
it can read and reset/delete codes
Old Feb 28, 2009 | 12:39 PM
chevyz2801's Avatar
I vote HP tuner someone had one for sale on here not that long ago.
Old Feb 28, 2009 | 08:06 PM
tording99Z28's Avatar
I have HPtuners and I love it. So powerful to do pretty much anything you want. I got mine used for $400 with 6 credits left. An awesome investment for $400, just keep your eyes open for a used one with some credits left.
Old Feb 28, 2009 | 09:08 PM
01ssreda4's Avatar
check the fluid level. i lost 1st and 4th and noticed the fluid was low. shut the car off and they came back. drove home and filled it up and they never went out again...
Old Mar 1, 2009 | 12:18 AM
jag81's Avatar
well i just changed the filter and fluid and it started to come on and off again ille check it tomorrow morning its weird because it only does it wen its warmed up i think it is the fluid i might not of put enough in
Old Mar 1, 2009 | 01:11 AM
GT Griller's Avatar
trannys probably toast...and u only have 3rd and 4th till it gets hot and starts slipping.
Old Mar 1, 2009 | 02:17 PM
jag81's Avatar
i dont think its toast because its after it gets warmed up is wen it has all the gears an wen there there they still feel strong and i checked the fluid and its at the right spot.
