Trans Temp Sending Unit
Old Mar 4, 2009 | 05:54 PM
jrpimp00's Avatar
Default Trans Temp Sending Unit
Has anyone installed a temp sending unit in the test port on the D side of the 4l60e and get accurate readings? Im getting ready to install one and I am still debating where to put the unit. Id rather not drill if I dont have to. Or is the highpressure line with a T fitting the most accurate place. Pics would be appreciated as well.
Old Mar 4, 2009 | 05:57 PM
tording99Z28's Avatar
I put mine there and compared to the temp sensor in the trans the one in the pressure port reads about 8 degrees cooler than the one inside the trans.
Old Mar 4, 2009 | 05:59 PM
Badazz 97 TA's Avatar
while its more accurate in the pan i have mine in the port on the drivers side.
With a scanner hooked up to my cars computer, the PCM read almost exactly the same temp as my gauge. Anything under 180* was dead on. once the gauge read higher the temps were usually about 10* colder according to the PCM.
Old Mar 4, 2009 | 06:02 PM
9000th01ss's Avatar
I put mine in the line to the cooler, and made sure it's grounded.
I did it this way to read the highest measureable temp of the fluid.
It's still +/- 5* of what hp tuners reads off the sensor in the pan.
Old Mar 4, 2009 | 07:08 PM
GoFast908Z's Avatar
Did the same!
Noticed a 15deg diff between the drivers side port and the exiting coolant line. Drivers side was 15 deg cooler.
