4l60e to 4l65e
Old Mar 4, 2009 | 07:19 PM
LS-1<>57's Avatar
Default 4l60e to 4l65e
Hi guys.......I'm sure this has been asked before, but need an answer if anyone can help. Is a 2006 2WD truck 4L65E a direct swap into a 1999 Z-28 4l60e..?? I know there are some input / output shaft differences to be considered.
Thanx in advance for the help..!! DK
Old Mar 4, 2009 | 07:47 PM
performabuilt's Avatar
LS1Tech Sponsor
You would only need to swap the tail housing and the manual linkage rod at the the side, Other than that its a direct swap.
The truck will have a smaller 2nd gear servo so I would swap that also .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
