What size stall?
Old Oct 16, 2003 | 12:40 PM
SShark's Avatar
Default What size stall?
I was wondering what stall I should get. I will be putting in a TR227/227 568 on 110 cam, Hooker long tubes, And ls6 intake and tuning of course. Also this with 3.23's On a 99 ss
Old Oct 16, 2003 | 12:46 PM
Patrick G's Avatar
LS1 Tech Administrator
Default Re: What size stall?
Depends on your goals. More street, more strip? Drag radials, ET Streets, Slicks?
Based on your mods, you probably need at least 4000 rpm stall. Based on your suspension, tires and goals, I can make a better recommendation on converter.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Oct 16, 2003 | 12:55 PM
SShark's Avatar
Umm I want more street than strip. Tires Drag radials, suspension Adjustable pan, Eibach drop springs, strut tower brace. And 4000 that's not to High?
Old Oct 16, 2003 | 01:22 PM
foff667's Avatar
LS1TECH Sponsor
i wouldnt go more than 4000 for a mostly street car...if its me id go with a tighter 3800 stall vert.
Old Oct 16, 2003 | 01:27 PM
Kevin Winstead's Avatar
I agree with Patrick, you should consider something around the 4000 stall range. I like the TCI 3800 converter, part number 242934.
It has very good torque multiplication (over 2.5) and good efficiency as well.
Kevin
Old Oct 16, 2003 | 02:32 PM
Patrick G's Avatar
Kevin's got a solid recommendation. If you don't get a TCI, consider a Yank SS 4000 or a Vig 3600.
__________________
Old Oct 16, 2003 | 03:00 PM
foff667's Avatar
LS1TECH Sponsor
i think pretty much everyone is right on this one.
lata
Bill
Old Oct 16, 2003 | 07:45 PM
Ragtop 99's Avatar
I like the 3800 with drag radials. Hooking a 4000+ on drag radials takes either excellent track prep or a light car.
Old Oct 18, 2003 | 08:55 AM
megathumpzillaX's Avatar
Yank 4000 isn't to high. I run a 4400 w/4:10s on the street and it's ok, little noisey at low speeds but it's worth it for when I put my foot in it. You can starsky and hutch it at will, but you can drive it like a granny if you want. Noisey granny, but it really isn't tooo bad. from about a 20mph roll it is freakish but you can almost keep it hooked.
Old Oct 20, 2003 | 12:06 AM
onebadz's Avatar
Another vote for the TCI 3800, you will get max. I think it will compliment your cam well for street use.
