torque arm bolts just spinning
Old Mar 6, 2009 | 06:01 PM
pooker's Avatar
Default torque arm bolts just spinning
I am trying to undo the two bolts that connect the torque arm to the rear end. They are lose , but are just spinning and will not loosen. What can I do to fix this? I assume this bolts are threaded into the rear end. Has anyone ever had this problem before?
Old Mar 6, 2009 | 06:12 PM
tptransmission's Avatar
Closed ex-Sponsor Account
No there are nuts on the top.
Old Mar 6, 2009 | 07:23 PM
mike13's Avatar
I tip when you put them back in on installation use a long punch or phillips head screw driver to line up the arm and housing holes. I had to use a floor jack under the rear to adjust the angle to get the holes lined up.
Old Mar 6, 2009 | 10:35 PM
waldershrek's Avatar
Putting them back in you will most like have to play with a floor jack under the pumpkin to get the right angle so the holes line up.
Old Mar 6, 2009 | 10:37 PM
smokintiresz28's Avatar
one of the bottom is just a stud for the mount brace undo the top first and remove the outer piece it fits in there like a clam shell
Old Mar 6, 2009 | 10:39 PM
I believe he is referring to the ones on the rear axle.
Old Mar 6, 2009 | 10:48 PM
pooker's Avatar
Dang I feel stupid! I got it now. I even broken an impact socket in half using one of those nut crackers to break it in half.
Old Mar 7, 2009 | 02:06 AM
01ssreda4's Avatar
very true, sometimes it takes a couple times to get it just right.
