Need Pro advice AGAIN lol
Old Mar 6, 2009 | 10:51 PM
9987ta's Avatar
Default Need Pro advice AGAIN lol
The trans was just rebuilt using a new GM low planet. Now it whines in 1st gear and reverse. The shop doesn't want to replace it saying its "normal " noise that happens some times when you replace things. Shop also says its a deep reduction so its noisier than other transmissions.
Here is the thing...it was dead quiet in 1st before they replaced this part. What is your thoughts on it? Please if you think it needs setting up some kind of adjustment spill it. LOL Is this a problem in 4l60e's or am i getting a bs story and they put a china piece in?
I tried running it hard in 1st and it doesn't seem to get worse but it whirls-whines everytime.
Thanks
Old Mar 6, 2009 | 11:33 PM
performabuilt's Avatar
LS1Tech Sponsor
It should not whir
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 6, 2009 | 11:59 PM
9987ta's Avatar
so whining is ok? Its a odd noise,whines but also has a odd extra bit of whir at times. Seems the harder you drive it the quieter it is.At light throttle to medium throttle its there and audible just to the point you notice it over everything else going on.
Old Mar 7, 2009 | 01:16 AM
9000th01ss's Avatar
I had a problem like that with a 700R4. Took the trans out only to find a screw I put in the floor to hold a corner of carpet down was hitting the transmission and transfering noise throughout the whole floor.
Maybe check the mounts and stuff like that.
Old Mar 7, 2009 | 05:44 AM
9987ta's Avatar
Only loose screw is the guy who thinks i'm going to accept this noise as normal.
Old Mar 7, 2009 | 06:54 AM
FLT's Avatar
FLT
Why was the planet replaced to begin with? Was it damaged? Did something in the unit let loose? Need a bit more info here. I'm guessing that maybe there is a bad bearing in the unit or the planet that was used is a cheap knock off. Vince
Old Mar 7, 2009 | 07:37 AM
9987ta's Avatar
The shop claims one of the pinion bearing was noisy LOL I'm starting to smell a rat. He purposely stated he bought the part from GM. I'm calling him out on this...monday i'm giving him the choice of fixing it or going to another shop and sending the repair bill. I personally think he bought a chinese knock off and gear pitch is off a little. I've worked on alot auto trans back in the day and i've never heard such a odd noise as this. Its a whining whirring sound that seems to be loudest when the gears are loaded lightly or as it shifts into second. I tried pulling out hard and breaking it but it holds together ok. I'm just guessing its strong but poorly machined, somethiing like that.
He wants to drive it a month then drop the pan and check the magnet.............
Old Mar 7, 2009 | 08:54 AM
FLT's Avatar
FLT
It is possible that a bad bearing behind the planet or behind the support is pitted causing an issue. The ring gear normally does not produce a noise however I have seen some wear on the sun gear for the rear planet. I would ask if these pieces were replaced. I have seen the knock off planets produce loose pinion gears. I have never used them and I now wonder if the noise you are hearing is what causes it. I wish you the best of luck. Vince
Old Mar 7, 2009 | 01:17 PM
9987ta's Avatar
Vince TY I mentioned your post and info he is pulling it back apart
Old Mar 9, 2009 | 04:40 PM
9987ta's Avatar
No good news.....he took it apart and can't find anything wrong. He is ordering another gm planet and putting it back together. I don't think hes too amused about it either.
Old Mar 9, 2009 | 07:09 PM
9000th01ss's Avatar
Maybe it's something weird, like....like something transfering normal noise and amplifiying it.
Or maybe he put a bearing in upside down and isnt admitting to it.
Old Mar 10, 2009 | 07:01 AM
9987ta's Avatar
He claims everything looks good, I think its because of a new part mixed with old parts. Its ashame it made so much noise if nothing is really wrong. I can't expect the guy to replace parts that look good. He is replacing it with another gm planet. Maybe it will be quieter now.
Old Mar 11, 2009 | 09:40 PM
9987ta's Avatar
He replaced the rear torentin bearing and the noise is gone. YIPPEE
Old Mar 17, 2009 | 11:20 PM
9987ta's Avatar
Things are not going good.....the fluid is turning black, it doesn't smell burnt just looks black. It shifts ok and works ok, but it feels a little tight when you drive the car like the car is holding back. Ever see black fluid in a trans that was just rebuilt? This is my wifes daily driver, i'm not up on these newer e type transmissions.
Old Mar 18, 2009 | 10:20 AM
9987ta's Avatar
I hate to say this but finding an honest trans shop seems to impossible! He has about every excuse in the book why the fuid is black! Starting to **** me off!
Old Mar 18, 2009 | 11:14 AM
crzytown69's Avatar
It sounds like the transmission may be failing. Fluid that turns black quickly, would indicate excessive heat caused by the clutch packs slipping in the transmission. Is what I have alwasy been told....
Old Mar 18, 2009 | 11:42 AM
LS1Tech Sponsor
Unfortunatley sounds like you have another issue now Sorry to hear of your miss fortune
I was going to mention he should change the torington bearing both at rear of case and under planet, The can become pitted either from rust or a bad engine to chasis ground making and anoying whizzing whining sound , I have seen that a few times in cars years ago and not just GM particulary the poor ground issue.
__________________
Call 888-744-6542
Old Mar 18, 2009 | 03:50 PM
9987ta's Avatar
He is back pedalling now......i took the trans to him with CLEAN fluid and the lugs worn off 2 of the 3-4 clutch plates. He replaced those and the planet because he said one pinion was noisy, i never heard it!. Then it had noise in 1st gear so he replaced the planet and two rear Torrinten bearings. Now it feels too tight while you are driving and the fluid is turning black. He kinda of making light of it and mentioned a long time ago how i used dex 6 might be caising all these problems. I can see an attorney in my future................it doesn't slip and the fluid is not burnt but its turning very black. I KNOW what is coming next....oh you need a convertor.....then the sheeet will be hitting the fan. I go from a very minor trouble to all this crap? DAMIT!
Old Mar 18, 2009 | 03:54 PM
9987ta's Avatar
Performa i'm not far from you but your installer was hurt.
Old Mar 18, 2009 | 04:07 PM
crzytown69's Avatar
man im really sorry to hear your troubles with this...Thats the only reason i went with a reputable company instead of a local guy that builds th300s all day..... I hope you figure something out its starting to get nice out and that only makes things worse....
