tran ?
Old Mar 11, 2009 | 07:08 AM
bebo LT1's Avatar
Default tran ?
ive got a 94 Z28 auto trans and when shifting from 3 to over drive hit the rev limiter but dont slip or anything what would it be
Old Mar 11, 2009 | 08:49 AM
performabuilt's Avatar
LS1Tech Sponsor
Unless its be altered in tuning the 3-4 shift is set to such a high level it will not happen at WOT before you hit the limiter
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 11, 2009 | 03:13 PM
bebo LT1's Avatar
it has been tuned and has shift kit
Old Mar 11, 2009 | 11:14 PM
tording99Z28's Avatar
Did this start happening right after the tune or was it fine before? If it started doing it right after the tune then its more than likely the tune. With electronic transmissions the shift has to be commanded just a bit earlier to prevent the car from hitting the limiter before the shift actually occurs.
Old Mar 12, 2009 | 02:20 AM
LS1Tech Sponsor
the stock tuning will not allow a 3-4 shift at wot so if your tuner didnt change that then this would be normal
__________________
Call 888-744-6542
