TCI transmission experiences?????
Going to be needing a beefed up 4L60E for my truck, what do you guys think about the TCI trannies? Or any other suggestions for a truck application. I've also heard good things about fbodytrans.com. Just needing some feedback. Thanks
I like mine, but I'm kinda partial to TCI transmissions
Every transmission we build has the valvebody tested separately from the transmission. Next, the transmission is tested separately from the valvebody. Finally, we bolt the complete transmission to an engine and put it through it's paces. When you get the transmission and install it in your truck, it'll have a tag with the line pressures written on it. We even have upgrades available, just in case you ever plan to increase your HP.
K1
K1
You will need the harden input shaft and sun shell upgrade. The super servos will not be a bad idea either. Just call 1-662-224-8972 and ask our sale staff about all the upgrades.
Kevin Steele
Product Engineer
TCI Automotive
Kevin Steele
Product Engineer
TCI Automotive
With those upgrades how much H.P. should that be able to hold? Also, how long should that tranny last? I've put 110,000 miles on the stock one (thanks to the tranny cooler)so I'm not real hard on transmissions.
