stock torque arm will not go back in - PLEASE HELP!!!
Old Mar 14, 2009 | 10:20 AM
ARCTICWHITE98Z28's Avatar
Default stock torque arm will not go back in - PLEASE HELP!!!
I am trying to reinstall my stcok torque arm to the rear before I reinstall my trans. Like a dumbass I took it all the way off when I took out my trans. The car is sitting on 4 jacks stands. I am unable to get the torque arm installed to the rear because the end of the torque arm will not fit onto the bolt holes. It is too tight. I am not sure if possibly my torque arm is bent or what. I have tried lowering the car and no luck. ANY IDEAS??? Thanks.
Old Mar 14, 2009 | 10:24 AM
danhr's Avatar
put a load on the rear end
Old Mar 14, 2009 | 11:01 AM
Joshiedoom's Avatar
Put a jack under rear end and use it to put an angle on it. It will slide right on. I did it bymyself while lying on a creeper
Old Mar 14, 2009 | 11:51 AM
that worked -thx danhr
