Steel dowel that fell out of tranny?
Old Mar 14, 2009 | 02:16 PM
Jemo's Avatar
Default Steel dowel that fell out of tranny?
When I took the valve body and all out of the trans for the transgo kit, I heard a "clinking" sound against the concrete. Underneath the trans was a steel dowel about 1-1/4" long and 3/16" diameter. Can someone point me where this goes back?
Jeff
Old Mar 14, 2009 | 02:34 PM
FLT's Avatar
FLT
Sounds like the 3-4 accumulator piston pin. Look through your directions from transgo and you will see where it goes. You should be installing a yellow spring in this location.
Old Mar 14, 2009 | 02:42 PM
Jemo's Avatar
Thanks Vince. Sorry to keep bothering with all my simple questions.
Jeff
Old Mar 14, 2009 | 02:51 PM
FLT's Avatar
FLT
No problem. Here is a picture for you. Vince
