Can Fluid Be Low ? Shifts softly...
Drove the car for the first time after the swap yesterday. From a stop it kinda felt like the car had a stall converter which it does not. I noticed the trans shiffting very softly. If i got on it the rpms would go high and i would have to let off to shift.
Can the line pressure be too low or something ? I am going to check the fluid today and hopefully see whats up.
used a4 trans swapped in with the ls1. My tach is off from the swap. that doesnt have anything to do with the shift points right ?
Edit: 1 more thing, does the car really need to be running to check the fluid ? Thanks guys, appreciate the help.
oh ok. Gotta check. I know alot of fluid dumped out the tailshaft when i brought the motor home. Picked up 2 qts from the store. Gonna add slowly and keep re-checking to see where i am at.
