Need help with my 4000SS
I think it just the tune but not 100%. When the car would go from 2nd to 3rd it would drop rpms then raise back up then finally shift into 3rd sometimes it would hit the rev limiter then others it wouldnt. Out of 15 passes I was only able to make about 5 full passes
. 1st to 2nd wasnt as bad but it wasnt full right either. We tried changing mph and rpm shift timing but nothing ever helped.
SO what is some things I can check or try as far as the tuning aspect also would the 3.23's cause any kind of problem.
And it fills more like it is unlocking and locking to me but I'm not sure.
I use HP Tuners
I'll have to figure out how to upload the scan.
The problem is torque management, I've even seen TM removal write ups that are incorrect. But you have TM at some point because at the 1-2 and 2-3 shifts the timing dips to -10
That will cause a noticeable decrease in power.
I already know the rpm's and speed are wrong I was just trying different stuff to see if I could have some point to work off of.
I'll attach my tune if you want to look at it. Use the compare tab, all differences show up in light green. Check everything. engine dtc's, misfire counts, and the obvious like TM. I compared yours to stock and yours to my current tune with a converter, there are a lot of changes.
But 9000th01ss I pretty much put your tune on my car just to see what it will do. Well after a short drive with alittle playing(been raining so didnt want to get to crazy
) the car seems to shift good now and the wierd 2nd to 3rd shift is gone. But I have yet to go wot because of the wet ground and already fish tailing all over the place
but I'm sure its going to be much better. I will let you know what happens when I get a chance 2 go wot.Now I have something to work with. Thanks for all the help guys
. This is why I love LS1Be careful though, I manually dropped my car down to third at 90mph and found myself going sideways at 120, on dry road. Not sure if it was the converter, tires, sand in the road or all three. But it was scary as hell.
Well I had a friend out there and we started looking at everything and discovered that I still wasnt going 100% throttle. We checked the sensor no problem. So I decided to take 1 more trip down and this time removed my mat thinking it was keeping me from pushing the petal all the way down. Well warmed the tires up real good and left hard as hell and barely tapped the limter on the 2nd to 3rd but ran a 12.6 with my buddy in the car
. So I'm sure with no one in the car and alittle more tuning I will be under the 12.5 mark which is what I was hoping for.
SO just wanted to update yall and appericate all the help guys
BTW...the guy with the Vette, OMG that car is a pig for everything he has done to it. I came home and researched those heads of his and they are not recommended on anything smaller than a 4" bore! On top of that he is on the stock intake. That car should be trapping 125mph with everything he has done to it. That is what a poorly planned combo will do for ya. (I want to get those heads from him)
