Transgo 4l60E-HD2
I'd use ebay. 1-2 accumulator piston Transtar under $10 USD.
https://www.amazon.com/ACDelco-24221..._d_product_top
So the kit part # seems to be 24221919
Meaning you can set up the 1-2 accumulator, then put it aside.
Set up the valve body, set it aside.
set up the servo, set it aside.
Drill out the plate, set it aside.
PAGE 1
Step 1 Set up and Install the servo. (good to do with the valve body is set aside and you can see the band)
Step 2 Remember what piston size you have (second servo) remember it so you can choose the right accumulator spring IN THE VALVE BODY.
Page 2
Do all the work to the valve body and turn the page.
Page 3
Put the converter isolator valve in. Now set the valve body aside.
Page 4
Drill the holes in the plate and set it aside.
Install the boost valve.
Page 5
Grab all the parts you have setting and ready to go and install them on the transmission.
This is so you can concentrate on one thing at a time.
