4l60 Broken! Gurus please help!
Old Mar 18, 2009 | 10:49 PM
STEEPSS's Avatar
Default 4l60 Broken! Gurus please help!
so i just finished putting a cam in my car this weekend, and it went off without a hitch. no problems. tonight i go to give my friend a ride, and i wasn't even really ripping it. I started in first, pulled to about 6 grand, bumped it to second, and zing. it hits the rev limiter. i stopped on the highway, and i had NO gears. not even reverse. Park does hold.
The transmission was built less than 3 thousand miles ago by a company in Florida by the name of Transmission Physicians. It was rebuilt due to pump failure. They went back in with a Beast sunshell, kevlar clutches, unbreakable pump rings, and other quality parts.
What could be wrong with my tranny?
Old Mar 19, 2009 | 12:11 AM
AutomagicLS1's Avatar
Sounds like you lost a pump. Pull a cooler line off and see if its pumping fluid
Old Mar 19, 2009 | 12:21 AM
STEEPSS's Avatar
alright. will do. pump was my first thought too, but i wanted another opinion.
Old Mar 19, 2009 | 01:59 AM
performabuilt's Avatar
LS1Tech Sponsor
I would say pump to and when you fix it be sure and check converter spacing we had a guy break three pumps before he checked it and found it was way excessive a year or so ago. Since then he has been good to go
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 19, 2009 | 09:29 AM
STEEPSS's Avatar
just to be sure, what is the proper converter spacing?
Old Mar 19, 2009 | 09:43 AM
LS1Tech Sponsor
With the converter fully back in the trans you should have about 1/8th inch space between the converter bolt pad and the felx plate bolt pad surface.
__________________
Call 888-744-6542
Old Mar 19, 2009 | 10:27 AM
Awake455's Avatar
Wait...you don't even have park? It's been a few years since I rebuilt a 4L60E so I'm a bit foggy. If the pump is toasted he should still have park right? Maybe check the back end of the trans...in the output shaft area or something? I could be smoking something too.
Old Mar 19, 2009 | 12:48 PM
STEEPSS's Avatar
i said i had no gears, and then i said park does hold. thanks for the input though. i just pulled a line of the cooler, and no fluid movement. so now it's lunch time and tranny pullin time.
