Anyone used goodfellas tranny's???
well was searching around on ls1tech and and came across a link for goodfellas transmissions. they have good prices and seems like a good set up. just wondering about them. i like FLT, and performa but just wondering if anyone has used these guys??
here are some details
from there site. -- this set up is 1300$ and is there best.
4L60E "The Boss "
The Boss Transmission comes with only the finest components and is built to be the highest standard on the market. Guaranteed to be the toughest, meanest, most durable transmission on the market. When you have this transmission in your car you will be the Boss of Bosses on the street or strip.
The Boss Comes with:
1. A Goodfellas reprogramming kit (we rework the valve body and completely go through it to make sure there are no stuck valves).
2. Raybestoes Z-PAK with 13 clutches (replaces the factory 5 clutches in the 3-4 drum). The Z-PAK is made up of heat treated steels that withstand more heat, delivering longer transmission life.
3. Raybestoes high temp energy clutches throughout the rest of the unit, along with all new steels, bushings, and rings.
4. A .500 boost valve (insures nice crisp clean shifting with no delays).
5. 4140 hardened pump rings
6. Teflon Pump bushing (allows more abuse)
7. 10 vane pump rotor
8. 29 element sprag
9. Sonnax Wide Open Throttle Valve
10. Sonnax Sunshell (three times thicker than factory).
11. Hardened input shaft and drum.
12. Kevlar band
13. Corvette servo (has 30% more holding power, giving you full throttle shift with out burning up the band).
14. We block off the 1,2,3,4 accumulators to give you a solid, firm, and crisp shift. We discard the springs in the accumulator to eliminate problems associated with springs breaking.;
The Boss offers excellent versatility for uses such as: daily driving, street/strip, extreme towing/pulling, extreme 4x4 (rock climbing), and nitrous applications. We have even put one of these bad boys in a custom made!
4L60E "The Boss "
8. 29 element sprag
12. Kevlar band
