Which STR on new billet verter?
Old Mar 26, 2009 | 06:12 AM
koolaid_kid's Avatar
Default Which STR on new billet verter?
I just ordered a new stage 2 trans with billet converter from Performabilt. The person was very nice, and when I told him I was already running a 2.1 3400 verter, he placed the order for a 4000 2.1 verter. But I was not totally comfortable with this, since recent threads had suggested that a lower STR might be more suitable.
My car: Weekend warrior, turbo LT-1, full weight (3700 lb.), estimated 600 rwhp, with everything else built correctly. The 10 bolt is still intact, but not for long.
What should I order as a converter? PB has been very nice about this, but I only want one converter.
Old Mar 26, 2009 | 08:44 AM
performabuilt's Avatar
LS1Tech Sponsor
If its any consulation though I realize its a pain to do the billet converters do have one free restall. Just so you will know.
Frank
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 26, 2009 | 09:10 AM
12secSS's Avatar
To determine a good STR, the intended use of the vehicle is needed (ellaborate on weekend warrior). Also what kind of tires if it will be drag raced? What differential gears?
I typically recommend a higher STR for drag racers on slicks, but I also recommend a low STR for drag racers who run on street tires. Daily drivers I will recommend a middle of the road STR, which also works for road racers.
Old Mar 26, 2009 | 09:39 AM
To me, a weekend warrior is a car that is only driven in nice weather and only to events where its performance may be demonstrated.
I run 255x50x16 on the street.
I will run 315x35x17 on the strip and during street runs.
I have a 3.42 gear in my stock 2 series 10 bolt.
My goal is to hook so well that a 9" must be installed.
Old Mar 26, 2009 | 09:01 PM
allbaugh_04's Avatar
I use mine the same way you use yours...mine happens to be 2.2. IDK if it's ideal but thats what i got.
Old Mar 27, 2009 | 12:08 PM
12secSS's Avatar
If those tires are drag radials, what brand? Based on this the 2.1 would work fine, if the tires are MT street radials you can up it to a 2.2 or 2.4 (beeter launch and better ETs, but more prone to spin the tires).
Old Mar 28, 2009 | 07:17 AM
chris718's Avatar
For what its worth it is impossible to get actual stall torque readings on any combination without an in car test and a machine to measure it.There are converter dynos that test this but the results will never be completely accurate once the cars engine is on 1 side of the trans and the weight of the vehicle is on the other.Until someone creates an in car test and has a database of results they can only predict this # although the window of opportunity for different results is very small.
