Where to mount tranny cooler?
Old 10-25-2003, 11:03 PM
theblur98ss's Avatar
Default Where to mount tranny cooler?
Where/how is the best spot to mount a tranny cooler? I wanted to mount it in front of the rad but then the lines won't clear. I mounted it on the back side below where my radiator supports mounts. I don't think it's getting enough air. It's running pretty hot. Thanks for any tips.
Old 10-26-2003, 02:15 AM
Gev
Gev's Avatar
Mount it in front of your condensor above the air dam. That is the best place to mount it. If not possible, mount it anywhere and get an electric fan for it.
Old 10-26-2003, 10:45 AM
Quickin's Avatar
Don't put it in front of the radiator. As soon as I did that my temp would shoot right up to 210 as soon as the A/C went on. With the A/C off it never, regardless of how I drove it, would go above the 185 mark. It started the day I had it installed in front of the radiator. Its getting moved next week.
Old 10-26-2003, 08:18 PM
Jeffs99SS's Avatar
I mounted mine "Dope style." It mounts it parallel to the ground between the air dam and the front fascia (on the passenger side). I may not be the best spot, but worked well since I am running an FTRA and was therefore space limited. Under normal driving, my trans temps never get above 170-180. Stop and go for a while will get it up around 200.
Jeff
Old 10-27-2003, 10:57 PM
WILWAXU's Avatar
Here's how I have mine..
http://www.johnbrown.net/wilwaxu/transcooler.html
