4K Stall 2 much for DD?
Old May 4, 2009 | 07:26 PM
AgentLS1Z's Avatar
Default 4K Stall 2 much for DD?
Prob been asked b4 but i couldnt find anything...I have a 98 Z with 2.73's ive been thinkin about getting a Yank 3600 but was also interested in the 4K stall. Is that too much for a DD? What if I put some 3.42's in it? Still too loose?
Old May 4, 2009 | 07:36 PM
CavPat's Avatar
I don't think a 4k stall is necessary if you've got a stock cam, but get a bigger cam and some gears with that 4k stall and your car will be a whole different animal.
Old May 4, 2009 | 08:26 PM
DSkyles's Avatar
A 4k stall is way overkill on a stock cam. With 2.73's it will feel loose and be a nightmare driving around town. I would be looking at something like around 3200 maybe? My tuner is an engineer and nationally known. He told me to go no bigger than a 3400 with 3.73's and stock internals. With the stock cam you miss the peak of the torque curve with a 4k stall. So I guess go for the 2800-3200 range and get a 9" converter that way if you get bigger stuff down the road you can get a restall.
Old May 4, 2009 | 09:04 PM
2002SS#1811's Avatar
With the mods you have I would not go with a 4000. I ran a SS3600 on a stock cam and it was fine. Did heads/big cam and went to the SS4000. 3600you will not regret it...
Old May 4, 2009 | 09:12 PM
AgentLS1Z's Avatar
^ yea thats what i've heard i think ill go Yank 3600, when I put 3.42s in the rear would it make it more managable? ive heard 3.73s are a bit too much.
Old May 4, 2009 | 09:15 PM
TA1364's Avatar
How fast do you want to go? If you want to go fast do not go small. 4000 is not to big for a stock cam.
Old May 4, 2009 | 09:22 PM
02 z/28's Avatar
I had a 3500 stall when I was stock and I wished I would have went bigger.I say go for it
Old May 4, 2009 | 09:28 PM
AgentLS1Z's Avatar
yea thats why i think ima compromise with the 3600, i think id get so sick of drivin a 4000 lol. I'm def gonna put my stock catback on with a cutout, im already getting sick of the LM2. Its like driving a garbage truck, sorta.
Old May 5, 2009 | 03:32 PM
john563's Avatar
4400 stall and 3:73
Old May 5, 2009 | 07:18 PM
zracer323's Avatar
I wouldnt be afraid to be a 4k in it especially if you plan on getting a cam down the road. When tuned correctly a stall like that will still have good drivability
Old May 5, 2009 | 08:12 PM
AgentLS1Z's Avatar
^ is that true? I couldnt imagine what its gonna feel like with whatever stall I get. I heard launching from a stall would feel similar to getting slammed in the back by a speeding Semi. How long does the 10 Bolt usually last from launching with a stall? lol
Old May 6, 2009 | 06:40 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
With a stock cam and those gears a 4000 will be a bit much. Particularly if you run a high str. A lower str and a 3600 will be much better.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old May 6, 2009 | 08:11 PM
drone's Avatar
running the pt4000 on a stock cam. Driving it around doesnt bother me. I plan on getting heads and a fairly large cam.
Get the stall to suit your future mods. Its still gonna be faster than the stock stall even if its not right for the stock cam.
Old May 6, 2009 | 08:20 PM
gillbot's Avatar
I went with a smaller converter and regretted it, not I got a PT4000 and couldn't be happier.
Old May 6, 2009 | 08:42 PM
AgentLS1Z's Avatar
gillbot, what kinda gears were you running when you first got your 4k stall? Are these stalls hard on the LS1? or mainly just destroy our trans's haha
Old May 6, 2009 | 09:26 PM
Cooler an a shift kit have = no problems here. At some point a fully prepped trans will be swapped
Old May 6, 2009 | 09:34 PM
AgentLS1Z's Avatar
Okay...I see you have the SS4000 would a PT4000 be better cuz it has a lower STR?
Old May 6, 2009 | 09:39 PM
JonCR96Z's Avatar
PT4000 with stock internals and stock 3.23 gears. It take a little getting used to. I wouldn't get anything less were I to do it again.
A stall is easier on your trans during part throttle operation. Just have a good cooler.
If you have a loud exhaust, that might get old after riding around at 3000 rpms all of the time. With more gear it would be even more drivable and you could set your lockup speed a little lower as well.
Old May 6, 2009 | 09:40 PM
fastlane02's Avatar
depends on what else you want to do to your car. if your going to leave your 2.73 and leave the motor stock then i say 3k-3200.
4k is way to much for a stock car.
figure out what you want to do with the car and match everything to it.
good luck
JonCR96Z's Avatar
I've always heard that the SS converters feel "tighter".
