converter unlocking....advice
Old May 10, 2009 | 12:23 AM
ls1adamls1's Avatar
Default converter unlocking....advice
ok so i just had the tranny in my 97 lt1 rebuilt. i had them install a brand new 3600 yank converter. the car shifts perfectly but whrn im cruising down the free way the converter will lock up at lower speeds but then it will unlock at 65mph or higher and wont lock back up. i know its nothing in the tranny.
is this normal? what can this be?
Old May 10, 2009 | 01:08 AM
tatasta's Avatar
Same problem here.... Subscribed.
Old May 10, 2009 | 01:26 AM
performabuilt's Avatar
LS1Tech Sponsor
tuning issue max out missfire threshold
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 10, 2009 | 02:57 AM
ls1adamls1's Avatar
so its a tuning issue? are my shiftpoints off?
Old May 10, 2009 | 10:03 AM
LS1Tech Sponsor
In dont know about your shift points but the issue your having is relativley common after installing a high stall converter. Your tuner should be able to take care of it easily enough.
__________________
Call 888-744-6542
Old May 10, 2009 | 10:29 AM
ls1adamls1's Avatar
ok cool thank you
Old May 11, 2009 | 01:18 PM
ls1adamls1's Avatar
i just heard that a misfire code can cause the converter to unlock....is there any truth to this
Old May 11, 2009 | 08:27 PM
LS1 Sounds's Avatar
Yes, max out the misfire table as stated.
Old May 11, 2009 | 09:51 PM
ls1adamls1's Avatar
im sorry im not sure what max out the misfire means. is that the misfire code or just stating i have a misfire.
so once i change my plugs and wires and have the code cleared the converter should start acting properly.
Old May 12, 2009 | 07:36 PM
blakern's Avatar
ur cars not actually misfiring. I think it has somthing to do with the size and weight of the aftermarket converter that makes it pick up a false misfire. By maxing out the misfire tables it fixes the problem.
Atleast it did for me.
Old May 12, 2009 | 07:46 PM
blakern's Avatar
https://ls1tech.com/forums/automatic...nt-lockup.html
Old May 22, 2009 | 02:16 PM
ls1adamls1's Avatar
ok got my PCM back from ion at madtuners and the converter is working flawlessly!!!!!!!!
he did some other stuff too but i had him delete my misfire stuff and it fixed my main problem
Old May 22, 2009 | 03:04 PM
tording99Z28's Avatar
Usually you don't completely delete the misfire system, you just max out the tables so its not as sensitive. In the case that you actually do have a misfire you want to be able to know just in case you can't tell by listening to the car. What he did will work but from my experience its not what "most" tuners do.
Old May 22, 2009 | 03:08 PM
ls1adamls1's Avatar
well maybe he just maxed them out. i told him what people on the forums were telling me to do. most people can tell if the car has a misfire, i have never relied on a computer since all i used to work on is old school chevys.
but im happy with the tune and the car is running very strong.
