TCI or Vig
Old Nov 5, 2003 | 08:53 AM
2002 Trans Am's Avatar
Originally Posted by samz28
so you can make more noise (without moving rapidly) with a stall?? is that looseness?
Yeah a little extra noise. AT least that is my expierance, but I could be totally wrong with what looseness is
Old Nov 5, 2003 | 05:25 PM
The Guy in MY 99TA's Avatar
I say the TCI if the Yank is not an option. I have a Vig 3600 and I am not happy with the effeciency of this converter.
Josh S.
Old Nov 5, 2003 | 06:05 PM
What exactly does efficiency affect? Top speed?
Old Nov 5, 2003 | 06:15 PM
Dom's Avatar
Dom
How much HP is being lost. If there is 100hp going into the verter then there is 90hp coming out if it's 90% efficient. More efficient converters have higher mph.
Old Nov 5, 2003 | 06:48 PM
samz28's Avatar
and can we assume an inefficient converter is causing heat. Since the power LOST has to be converted to something right? more heat = bad for trans.
i suck as physics but it makes sense.
Old Nov 5, 2003 | 08:37 PM
highgear's Avatar
You could also consider a Midwest, custom made for your Stall and STR needs for about $450.
Old Nov 5, 2003 | 11:48 PM
Very interesting concept on this efficiency stuff.
So what does the vig put out about? 95%, Yanks are around 97%? Stock converter???
This thread is becoming very interesting!
Old Nov 6, 2003 | 02:26 AM
Colonel's Avatar
Stock = 94%
Most Vigs = 92-95%
Most Yanks = 95-97%
Yes, less efficiency means more heat generated. More efficiency means higher trap speeds (all else, such as stall speed, being equal.)
Old Nov 6, 2003 | 02:33 PM
samz28's Avatar
Efficiency is rated when locked up or unlocked? or what?
Old Nov 8, 2003 | 08:48 PM
scalemaster's Avatar
TCI here and love it
Old Nov 16, 2003 | 10:06 AM
BLK02WS6's Avatar
Josh S.
Why do you say this? Looking at your mods and your times (N/A), I think that the converter is working good! I have a TCI, and I am very unhappy with it - I only gained 3 tenths with it (12.46 to 12.13)! I'm thinking of switching to a Vig!
Old Nov 16, 2003 | 05:33 PM
  #32
42NightZ28's Avatar
I realize that you can't afford the Yank right now but why not wait till you can? Do it right the first time so down the road you arn't mad at yourself for not getting what you really wanted. I got a Yank SS3800 that combined with the 3.70 gear and slicks took a full second off my times with the stock converter and 2.73 gear.
Old Nov 16, 2003 | 06:04 PM
  #33
lol, I am starting to lean toward paying the extra money for the SS3800 now, especially with my 2.73 gearing.
Old Nov 16, 2003 | 07:55 PM
  #34
BLK02WS6's Avatar
AMEN!! And then if you are like me, you end up getting what you wanted in the first place and wasting the money you spent on the one you didn't really want
You would think I would learn - even my wife says get the good one, but what do I do - try to save a dollar and end up spending even more in the long run!
