Got my upgrade A4 upgrade parts
Old Nov 6, 2003 | 03:38 PM
offaxis's Avatar
They list there prices on there website. Most expensive part I think was the torque drive kit . All these parts start to add up but if you look at alot of the stage 2/3 trannys talked about on the boards some dont even have some of this stuff Ive listed and cost well over 2 grand. I am sure they are great but my car gets driven all the time and raced almost nightly on the street so I need the best parts I can get . Id hate to pay 2 grand for just better clutches a corvette servo and the beast sunshell . Those parts dont cost very much.
Old Nov 6, 2003 | 03:41 PM
mikemodano9c's Avatar
Originally Posted by offaxis
They list there prices on there website. Most expensive part I think was the torque drive kit . All these parts start to add up but if you look at all the stage 2/3 trannys talked about on this board some dont even have some of this stuff I have and cost well over 2 grand. I am sure they are great but my car gets driven all the time and raced almost nightly on the street so I need the best parts I can get . Id hate to pay 2 grand for just better clutches a corvette servo and the beast sunshell . Those parts dont cost very much.
seems like you are planning on rebuilding the tranny yourself...i am thinking of trying...
i wonder if all the parts were bought how much someone would charge for the labor of rebuilding...
Old Nov 6, 2003 | 03:49 PM
offaxis's Avatar
I actually have a guy building it for me. I help out alittle. I pay 300.00 for the build since I supplied the parts. The builder has done lots of these trannys and has had a worked 700r4 in his 406ci Impala for over 7 years now without any problems. As stated before the build is very important there are so many possible things to mess up in these trannys if you dont know what you are doing it can be a big mess.
Old Nov 6, 2003 | 05:35 PM
Stone0fFire's Avatar
reds last longer then blues for a daily driver?
hey, thats info i didnt know!
thanks colonel!
someone should compile a FAQ for our trans
kinda like colonels nitrous files
heh heh
Old Nov 6, 2003 | 07:32 PM
dissonance's Avatar
I have the Mega Hoss Deluxe from KDS and installed it myself; I added a few other options, large pan, cooler and TCI racing fluid.
Seem to be a strong setup, I don’t have a lot of track time on it, but have not seen any problems.
The clutches in my stock Trans looked fine, 4th had some wear. The sun shell did not take the abuse so well. Duh broke the sun shell. The stock 4l60e can hold up well if you cool it down some. The sun shell looks to be the weakest part in the stocker.
What has been upgraded in the 4l65e?
Old Nov 7, 2003 | 12:31 AM
a decent amount has been upgraded inthe 65e, but gm specs it for only 5100 rpm shift points? i dunno
its supposed to handle 400 ft lbs of tq...whoopy...it does come with an upgraded input/output shaft...there is an article somewhere...do a google search
it 1800 bucks new on gmpartsdirect i saw...
i think an upgraded 4l60e is a better bet
2nd in my trans is slipping...thats why im looking for a rebuild asap...
Old Nov 9, 2003 | 10:44 PM
PunkNPonys's Avatar
Has anyone used the TCI perfromance rebuild kit for 4L60E? I got that one because it was a good price and i am not running a lot of hp so i figured it would be ok. Does anyone know about it or maybe exactly waht parts it has? I already bought it but havent installed it yet. The part number is #378951.
Old Nov 10, 2003 | 12:47 AM
offaxis's Avatar
Tranny is in and I have put like 500 miles and abunch of passes on the street. All is still working which is a plus
Old Nov 10, 2003 | 07:00 AM
whitt1's Avatar
Good luck,I've broken a transmission with all those parts.I've burned up 2 sets of clutches,broken a 5 pinion planetary gear,flipped a 29 element sprag and blown 2 front pumps.Nothing is truely bullet proof.You've probably got a better chance of making it work in an f-body,but my 5700lb Tahoe is getting a 4L80E this week.
Old Nov 10, 2003 | 08:22 AM
dissonance's Avatar
Great to hear that, to be honest when I did mine I did not think it was going to back it's self out. Any leaks? What kinda pan did you use? I got a Derale it was one the cheaper pans but it's very nice I would recommend it to anyone. I also got a b&m racer cooler; I think I will be getting one of the Derale coolers later. Fittings on my B&M are leaking...
I think I checked my fluid for weeks after I did my install... it would seem too easy to burn the thing up because of low fluid.
Keep us updated!
Old Nov 10, 2003 | 08:43 AM
offaxis's Avatar
I used the stock pan . I am goig to change my fluid in a week or so and I will probly go with a better pan at that time. I just didnt want to spend money on a pan until I knew it would be going for a while even though they are cheap.
Jeremy
Old Nov 22, 2003 | 09:03 PM
  #32
offaxis's Avatar
Ok Guys
The new tranny is slipping hard in 3rd and 4th gears.
I did get 1150 miles on this one. LOL
I cant figure this out I have just about every updated part available. Any Ideas ?? Im looking to a T400 but I know that will slow me down a bit and I hate to loose OD
Old Nov 24, 2003 | 08:52 AM
  #33
dissonance's Avatar
Ok Guys
Your trans could be slipping because of the cars power...
Did you check the clearance of the clutches? You upgraded the servo's right? Both where after market? If those are not right then you could have problem like this. Fluid level ok? “I know I know but that could be the problem”? What kinda fluid did you end up going with? I put a tci racing fluid in mine; I think the tci stuff is type f? Or the older stuff “not “dextron”
Did you take any of the valves out of the valve body? Did you use a pump aliment tool?
