Which AN fittings and hose to use for trans cooler
I'm looking at swapping my B&M 19k trans cooler for a B&M 24K and I wanted to use AN fittings and stainless steel braided lines when I install it. I'm not sure what size fittings I would need. If anyone has any input it would be greatly appreciated.
I think B&M has a 24K cooler that uses the AN fittings. I have seen them in a kit with the cooler. However, I prefer the rubber lines and clamps.
I used 6 AN fittings. But the only hose I could get was from work and was high pressure so it had the dual braiding. I pealed the outside layer off to make it thinner. But use 1/2 NPT to 6 AN for the cooler then use 6 AN fittings and line. Then use B-nuts on the hard lines. I didn't use the flared ones but you can use them too.
