!!! Still leaking... Need Help !!!
Old May 21, 2009 | 04:45 PM
7th Darkness's Avatar
Question !!! Still leaking... Need Help !!!
So I was having a problem with trans fluid coming out of the vent tube when driving. So I drained the fluid, flushed the lines, and replaced the filter.
When I was doing this noticed that some fluid was leaking from the front of the trans, looked up through the inspection plate and noticed fluid leaking from the front seal.
So I had the front seal replaced... and no luck still leaking. Good amount to, small drip when on, then big dumb when shut the car off?
Bad TCC Solenoid? If so anyone have part#? Any other ideas?
Old May 21, 2009 | 06:50 PM
DeepV's Avatar
I have the same issue, i noticed mine seems to be fine until you do a pull in 3rd gear and that's when it will spew out fluid.
My original tube some how came undone and i put in a new one and routed it into the engine bay, sure enough after a few pulls the immediate area around the tube was splattered with ATF and i'm in the same boat as you. I'd love to hear some explanations or theories if anyone has them.
Old May 21, 2009 | 07:01 PM
DeepV's Avatar
Here's a thread i Just pulled up on the subject
https://ls1tech.com/forums/automatic...nny-fluid.html
Hope it helps.
Old May 21, 2009 | 07:15 PM
Yeah but mine is leaking from the front now?
Old May 22, 2009 | 09:12 AM
UPDATE:
Car still shifts normally. Seems to get hot quick and of course the fluid that leaks out from the front is a problem. When I get home from work I will try and get some pictures if that will help.
