B & M Shift Plus
I saw this on the QTP website...the B&M Shift Plus
Shift Plus simply recalibrates your transmission's hydraulic system electronically. The Shift Plus shift firmness not only makes driving more fun and pleasurable, but slippage and heat are reduced - extending the life of your trans- mission! Anyone can install a B&M Shift Plus in minutes with a few simple hand tools. This new design allows you to improve the transmission's shifting performance with- out removing the transmission pan or valve body. The B&M Shift Plus electronically enhances shift quality and is adjustable. A simple flip of the switch allows the transmission to operate in the performance mode. Flip it back and you ore back to stock!
Part # Description Price (US)
70380 Shift Plus GM 4L60E $39.99
Is this a worthwhile mod to do....or should I just save the money up to buy a Preadator to do the same thing?
Thanks
Thanks
