4l65e?
Old May 27, 2009 | 03:41 AM
Twisted636's Avatar
Default 4l65e?
ok so the ls1 camaros have the 4l60e but what is a 4l65e? is it stonger then the 60e?
also where is the best place to find a rebuild kit for the 60E?
also will the 65e bolt right up the ls1 and work with no problems?
Old May 27, 2009 | 08:43 AM
performabuilt's Avatar
LS1Tech Sponsor
The 4l65e and the 4l60e are essentially the same trans. The 65e has the addition of 5 pinion planets as oposed to 4 pinion in the 60e and a few other minor changes.
In stock for it is not apreciabley stronger than the 60e but in the 98 up camaro is a direct swap with the exception of changing the linkage shaft and the tail housing.
Electrically and physically they are the same as long as the 65e is a 2wd unit.
If your looking to built one or the other the kit and parts would be the same and you can just add the 5 pinion planets to the 60e but make sure they are OEM style.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 27, 2009 | 04:29 PM
PedaltoMetal's Avatar
MY 60e has GM 5 pinion planets, can I call it a 65e now?
Old May 27, 2009 | 04:35 PM
LS1Tech Sponsor
For all practical purposes I would say yes. lol
__________________
Call 888-744-6542
