th400 transbrake for reverse
Old May 27, 2009 | 05:41 PM
yak's Avatar
yak
Default th400 transbrake for reverse
So I installed a th40 with a brake in my car last fall but reverse didnt work, I remember someone saying it had to do with the RMVB and having to engage the brake to goin reverse. is this true? do I just toss it in reverse hit the brake and hit the gas or am I missing something?
Old May 27, 2009 | 05:59 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Depending on which valve body you used if it is a pro brake then most of them you have to put the car in neutral and press the brake button to engage reverse. We offer a street brake that you don't have to do this with. Simply put in reverse and back up!!!
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old May 27, 2009 | 07:11 PM
01FbTaWs6's Avatar
yup. Mine you cant use neutral for reverse. It has to be in reverse and then press the trans brake button down, wait for it to engage and back up.
Old May 28, 2009 | 06:21 PM
LS1Tech Sponsor
It all depends on the manufacturer of the valve body.
Greg
__________________
1-866-726-8358
FTIPerformance.com
Old Jun 1, 2009 | 02:41 PM
01_ram-air's Avatar
I have an FTI TH400 w/ transbrake. All of my gears work w/out engaging the T-brake.
Old Jun 2, 2009 | 07:46 PM
LS1Tech Sponsor
Thats because of the brake design i have in your transmission. A protree brake with safety reverse you have to mash the brake to back up.
Greg
__________________
1-866-726-8358
FTIPerformance.com
Old Jun 2, 2009 | 10:22 PM
01FbTaWs6's Avatar
yup, mine is a pro tree.
