can a 4l80e be converted from 4x4 to 4x2?
well that's the question i found a 4l80e but its 4x4 and i was wondering if there is a kit to put a tail shaft on it so i can use it in a 4x2 or i am dreaming.
I would not suggest drilling the freeze plug in that back of the case. There is an actual seal that is apart of this plug with an orifice in it for the 2wd models. Also on the 4x4 models the rear planet carrier can have a pressed on reluctor or it might not. If you have a model without one, sonnax sells the relutor that can easily be pressed on. Vince
