CSR Flexplate
Old Jun 6, 2009 | 09:30 PM
tee-boy's Avatar
Default CSR Flexplate
Started the motor up first time w/ CSR's new flexplate. The bolt heads on the plate were hitting the starter housing. Had to pull the starter off and grind down the housing to get the flexplate to clear.
Just a heads up.
Old Jun 10, 2009 | 10:14 AM
js2fst's Avatar
they told me they never heard of that problem on mine. Same problem
Old Jun 10, 2009 | 06:24 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Talked to csr today as we have had 3 people with the same problem. Send them back and we will either refund your money or install a new shorter bolt.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Jun 10, 2009 | 10:14 PM
tee-boy's Avatar
hmm... my neighbor told me they just changed the name of their company.
Old Jun 11, 2009 | 01:09 PM
tee-boy's Avatar
well, I don't want to cry wolf. I'm going to get my brother in law to check the heads on the converter bolts. maybe it's the converter bolt heads and not the flexplate bolts.
Old Jun 11, 2009 | 05:16 PM
LS1Tech Sponsor
Let me know
Greg
__________________
1-866-726-8358
FTIPerformance.com
Old Oct 16, 2010 | 10:25 AM
00silver6's Avatar
what was the result of the issue? im getting ready to go take my starter off for the same reason.
Does the converter push any? if so ill have to grind on the factory starter housing a little. ill post a picture up later.
Old Oct 16, 2010 | 12:51 PM
00silver6's Avatar
the blue arrow is where ya gotta grind a little on the stock starter housing. again this is a CSR flexplate. just wanted to post this to help anyone that needs it
Old Apr 22, 2011 | 07:47 AM
Vetal's Avatar
I have test-fitted my CSR flexplate (manufactured March-2011) and bolts hit the starter...
Old Sep 5, 2011 | 10:20 AM
Vetal's Avatar
Ground down starter housing but now starter bendix occasionally (once in a few seconds on idle) hits ring gear... Is that because of the flexplate too, or did my starter suddenly went wrong?
