Trans question
For reference, I have a Vig3200 converter, a TransGo shift kit, and a B&M 19,000 GVW Trans Cooler.
On my last run, I was in 2nd for my burnout (like usual) but unbeknownst to me, my tires never spun.
So, I make the run, and it never shifts into 3rd, just bounces off the rev limiter in 2nd.
For fear of leaving my trans at the starting line, I quit racing for the day.
Weird thing is, on the way home, the trans is fine, shifts into and out of all gears normally.
Is there a difference with shifting under normal acceleration versus shifting at WOT?
And furthermore, do I call this situation a fluke and assume my trans is OK?
Thanks alot for any answers!
I've seen others who have a fluke issue and let the car cool down, restart it and it drives fine. Any WOT shift issues on the street since then?
But as far as normal driving, it's been fine.
I'm thinking if there was a real problem it wouldn't shift into 3rd at all... am I right?
It was only about 40 degrees Sunday at the track, and I was allowing ample time for cooling, so I don't think the trans would've been too hot... unless of course there's a problem with the trans cooler like you mentioned.
