G8 6L80E trans output shaft
Can the output shaft of the 6L80E trans be converted to use a standard yoke easily, or am I stuck with the ribber mounted joint that the G8 uses. On the GTO trans, you could just slip the yoke out and substitute a regular yoke, but it looks like the G8 can not.
Regards, John McGraw
