Tranny starts in 3rd sometimes?
For example, today I backed car out of garage and when I put it in OD and gave it gas I noticed it was in 3rd(I'm guessing) but as soon as I put it in reverse and back into OD I had 1st. WTF? Datamasters datalog says there are no tranny codes. Too me it's like the pump isnt working like it should. I'm running tranny cooler cause of stall and the cooler has been there over 2 yrs now. Would getting the tranny cooler lines crossed cause a restriction in fluid flow. I figured it doesn't really matter how you hook hoses up to cooler. Am I wrong? Someone at a local tranny shop said it sounds like my 3-2 downshift solenoid is going bad. Any truth to that?
Thanks in advance.
It drove great today, drove around for an hour or so then off to work. Then when I went to leave work and it did it again. Same as before I had to shift between reverse and drive till I felt the forward pull. Could the pump be going out? Other than checking for codes, I'm at a loss.
I've had numerous people tell me it's the linkage but I don't see how when there is two bolts that hold linkage to tranny and the gear selector just pops on or off so how can that be adjusted or off if it only goes on one way? Am I missing something here?
Tranny was fine before I did motor swap. I'll try and see if I can get any codes but if there no codes, what could it be?
If possible put the car on a 2 point lift, you in the car and running. Have a friend watch the linkage. Shift the car in to numerous gears and let your friend know what gear its in when you shift. If the linkage doesn't move, or hardly moves when you do so. This could be your problem.
No codes?
