how often should trans. fuild be changed
Old Jun 22, 2009 | 02:07 PM
badmfkr's Avatar
Default how often should trans. fuild be changed
I'm not sure so I ask the experts here on LS1tech.
how often should trans. fuild be changed? in miles and or in time?
I did a search.
Thanks
Old Jun 22, 2009 | 03:39 PM
TXZ28LS1's Avatar
when i got my 60E beefed up i asked the shop when should i change the filter/fluid. they told me every 20k miles. but if i knew how to change the fluid and filter i would honestly do it every year.
Old Jun 22, 2009 | 03:58 PM
badmfkr's Avatar
Default ha ha
dam man thats some funny *** ****.
sounds like you let MTV pimp the car.
Old Jun 22, 2009 | 04:23 PM
SSickLS1's Avatar
LOL!!
ANSWER:
as often as you can stand refillin and replacin filters. Just jack the car up high enough u can get the pan off and the filter neck slip fits onto the pick up tube. Replace the gasket, bolt up the pan and fill to the cold level on the dipstic thru the dipstic tube. Continue to check & fill w the car running repeatedly changing between neutral reverse and drive for short increments before rechecking until it stays level at the warm/hot crosshatch. DO NOT UNDERFILL!!!!! Treat ur 4L60E right and itll last a LONG time.
Old Jun 22, 2009 | 04:24 PM
SSickLS1's Avatar
Id suggest no more than 20-25k per service interval. Less depending on how hard u drive ur car.
Old Jun 22, 2009 | 04:44 PM
badmfkr's Avatar
Default pink fuild
I've had the trans. rebuilt w/ the TCI racer rebuild kit and TCI beast sun shell
after the planetary gear broke (going up a steep hill was kindof weird) it's been about 55K since rebuild and about 25K since fuild change consisting of dropping pan installing new filter.was planning on a 25K interval.
When I purchased the car in 01 the first mod was a 20K cooler. sense rebuild I've added a B&M 24K cooler in parrel w/ el cheapo 20K, TCI deep pan and a perma cool extrenal oil filter used as a 3rd cooler and filter.
even in extreme outside temps. the trans. guage reads 100 degrees on expressway and in city traffic usally around 125-185.
Whats this stuff I've been reading here about if it's still pink not smelling burnt then leave it alone.
Thanks
Old Jun 23, 2009 | 10:51 PM
SSickLS1's Avatar
you wouldnt believe some of the rediculous **** some folks say on here - as a mechanic i say anytime u can change fluid and a filter u should do it regularly.
Old Jun 23, 2009 | 10:56 PM
whytryz28's Avatar
I do the fluid every 10k-15k or so since the heat down here is pretty bad and I drive with a lead foot.
