1st gear is locked?
Old Jun 22, 2009 | 11:01 PM
2ktransam's Avatar
Default 1st gear is locked?
I'm finishing up my auto swap and I started the car tonight to check for leaks and it has no 1st gear. I have not swapped in an auto tune yet so I was just shifting gears manually while it was up on jack stands. All of the gears work shifting manually except for 1st. When I pull into 1st gear it locks the rear tires. If the car is off and I pull it into 1st the tires spin freely like they are supposed to. What's the deal? Could it be wiring or the tune?
Old Jun 23, 2009 | 01:28 AM
performabuilt's Avatar
LS1Tech Sponsor
The auto will not work without the tune and you would be in limp mode and yes locking the wheels in manual low would be a possible issue there.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 23, 2009 | 07:25 AM
2ktransam's Avatar
Thanks Frank.
