Question about driving in "Drive"
Old Jul 8, 2009 | 07:39 AM
Tuffguy610's Avatar
Default Question about driving in "Drive"
Hey guys,
Got another question for you all. I recently moved to an area that has a lot of twisty 35 mph roads to commute to work. I tend to put my suspension to use and carve the corners when I drive on the roads, so naturally I do not like leaving the car in overdrive during this stretch of my commute, so I put it in "D" or "Drive". I also like the fact that Drive locks up the converter at a lower speed, thus giving me the ability to directly use the torque of the engine to slingshot me through the turns while keeping a relatively low engine speed. My question is this: will I cause damage to the converter and its clutches or any other transmission component by leaving it in D while cruising between speeds of 30 mph to 50 mph on a windy road? The reason I ask is because the converter unlocks and locks a decent amount and I know the tranny was basically designed to run on overdrive 95% of the time. Please let me know as I have 85k on a stock trans with a cooler and I would like it to last.
Old Jul 8, 2009 | 08:54 AM
01ssreda4's Avatar
It will cause premature converter clutch wear from locking and unlocking, and it will cause slightly higher operating temps, but if you have an aux cooler you should be fine. I personally dont see the problem with it as long as the trans isn't overheating. I mean they were made to shift gears.......
Old Jul 9, 2009 | 09:07 PM
AGRV8TD's Avatar
I dont see it posing an issue unless your constatntly in stop and go traffic
Old Jul 9, 2009 | 10:58 PM
performabuilt's Avatar
LS1Tech Sponsor
I see no issue with it
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 9, 2009 | 11:23 PM
Z-RATED94's Avatar
You'll be fine. Either way the lock-up is still going in and out when needed.
Old Jul 10, 2009 | 10:44 AM
jimmyblue's Avatar
Moderator
I disabled lockup in 3rd with my first converter and
like it a whole lot better. I'm into 4th by 40MPH at
low pedal and that's good enough.
