93 Trans Am late shift to 2nd
Also your TV cable needs to be correctly adjusted asap. That can kill your tranny faster than anything. I limped around for a couple months going 1st to 3rd.
Changing the fluid no will do nothing but hasten the death of the trans. All the clutch material in the fluid is acting like a friction modifier and taking up the space of the missing clutch material. If you replace the fluid, the trans parts become more viscus and then there is actually less material between the metal disks. That will only lead to bigger issues. I think your best bet is to play with the tv cable to try and get the point to halfway normal, then look into a rebuilt with a new converter. Then again that's just my .02
