Strange leak issue....expert inside please
Old Jul 23, 2009 | 12:57 AM
babydeuce's Avatar
Default Strange leak issue....expert inside please
01 A4(2wd truck), 2400 fuddle stall, no internal mods, trans tuning done by blackbear.
The trans will be fine for weeks on end, drive it around on short and extended trips, no issues, no leaks. Car will sit for a week or so, I will get a puddle under the car. Puddle is coming from the small inspection hole in the bottom of the trans. I will add fluid, check level, drive, no leaks. Car will sit for several days, no leaks, drive it some more, no leaks....then out of the blue after the car sits for a week, I will come out to find another puddle. Sometimes the puddles are a half a quart or more....I just cant figure it out....thoughts?
Jack
Old Jul 23, 2009 | 04:53 AM
ramairws6's Avatar
Man this is weird! I have a friend with a Turbo 350 in his Olds Cutlass which is been doing the same thing for years. Nobody can figure it out. I'm starting to think maybe the dipstick or tube is the wrong length and we are overfilling it?? Thats my last idea since every seal or gasket has been replaced. Its one of these deals............
Old Jul 23, 2009 | 08:38 AM
performabuilt's Avatar
LS1Tech Sponsor
coming from the inspection hole I would have to guess possibly leaking around a pump bolt. As the trans sets fluid from the converter drains into the trans "normal" but when levels high enough to get to that bolt the fluid comes out
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 23, 2009 | 11:30 AM
babydeuce's Avatar
That is one thing that I had no thought of....I suppose the only fix is to pull the pump, or can I seal just 1 bolt?
Jack
Old Jul 23, 2009 | 11:44 AM
LS1Tech Sponsor
you can seal all the bolts without pulling the pump . But is it were me I would replace ORING.BOLT ORINGS,PUMP GASKETand FONT SEAL if i was gonna pull the trans
__________________
Call 888-744-6542
Old Jul 23, 2009 | 11:10 PM
ramairws6's Avatar
I tried this also on the turbo 350. Pulled the pump and replaced the o-ring and put sealant on all pump bolts. Still didn't fix it................
Old Jul 24, 2009 | 12:09 AM
LS1Tech Sponsor
I too have run into the replace it all and still leaked. Then its time to replace the case
__________________
Call 888-744-6542
Old Jul 24, 2009 | 12:11 AM
babydeuce's Avatar
Thanks for the input guys, but I am going to let it go for a while....I leave for Korea in 2 weeks, and I dont need the frustration of pulling the trans right now....when I get back, I will yank the tranny and take a look.
Jack
Old Jul 24, 2009 | 04:12 AM
ramairws6's Avatar
This was my next move. I really think the case is tweaked................
