SS3800 opinions please
Old Nov 18, 2003 | 04:43 PM
2002 Trans Am's Avatar
Default SS3800 opinions please
I think I am definetly going with an Yank SS3800.
Now I want to read about all the negative things about the converter, I want to hear all the problems I will run into, I don't want to be shocked when something goes wrong.
I'll be going with a 20K-24K cooler
Redline fluids (Which products do I need for the converter swap?)
Full dyno tune when finished.
I just read 1 today about the 2-3 shift with SES light but couldn't figure out what they meant
Old Nov 18, 2003 | 05:44 PM
42NightZ28's Avatar
I am glad this topic came up casue i would love to tell you and the world about the problems i am having with mine. WAIT!! i havn't had any problems with mine LOL its performmed flawlessly and i have yet to hear of one that hasn't performmed flawlessly. the only dark cloud in your sky is that becasue to own a 2002 if you decide to order a SS3800E like i have that your going to need to get either an aftermarket Flexplate or a Earlyer model one from yank like i did. Your only going to need 1 quart of trans fluid if all your doing is a converter swap.
Old Nov 18, 2003 | 07:20 PM
jruss's Avatar
yes i have one as well, flawless performance 1.5.. 60'on et sts hits real hard below 40mph ,you wont go wrong with this tc !!
Old Nov 19, 2003 | 08:17 AM
Originally Posted by 42NightZ28
The only dark cloud in your sky is that becasue to own a 2002 if you decide to order a SS3800E like i have that your going to need to get either an aftermarket Flexplate or a Earlyer model one from yank like i did. Your only going to need 1 quart of trans fluid if all your doing is a converter swap.
I wouldn't be ordering the "E" series, just a regular 3800, do I still need the flexplate for a 2002? What if I were to drop down to a 3600, do I still need the flex plate? If so who makes a good flex plate and how much? TCI?
Which ATF should I select from this group http://www.myoilshop.com/AutoPrds.html
Moderators please delete this link if it violates forum rules, I am unclear of them
Thanks
Old Nov 19, 2003 | 08:55 AM
42NightZ28's Avatar
if you are getting a regular SS3800 then no your stock flexplate will be fine.all converters on Yanks E line have 6 mountung hole and the flexplate on 01-02 cars only have three holes.
Old Nov 19, 2003 | 08:56 AM
Awesome...Less money to spend!
Old Nov 19, 2003 | 05:14 PM
35th LE SS's Avatar
I've had mine for almost a year now, and have had zero problems. Over 10,000 miles and not a single problem. Was a little disappointed with the 60' times, but have only been to the track twice since it was installed. Best I did on ET Streets was a high 1.7. However, with headers and the stall I knocked .8 off my 1/8 mile time. An 8.04 from an 8.80's. I think more practice, suspension mods, and better track prep and 1.6's are easily feasible. I love it and wouldn't change it, except maybe restall it to 4000 after a head/cam install.
Old Nov 19, 2003 | 05:24 PM
onebadz's Avatar
Dang 35th .8 is good keep up the good work.
WeS
