Recommendations for 4L60E upgrades?
Old Aug 2, 2009 | 04:30 PM
brossow's Avatar
Originally Posted by SteveB4C
Vette servo. whats a good place to get one or does anyone have GM part number?
Tons on eBay for under $20 shipped. Try this search.
Old Jan 19, 2013 | 01:48 PM
jdsuperstreet's Avatar
Originally Posted by performabuilt2
get the stock plastic accumulator pistons out and replace with a aluminum piston or sonnax has a pinless piston you have 3 of them in the tranny a forward accum which is in the VB and a 1-2 accum which is in the housing and a 3-4 accum which is in the case under the seperator plate...with a stock shell i recommend using a vette servo which you may already have stock anyway...follow the direction onthe hd2 kit and get a good cooler for it with a high stall dont use more than 1 washer in the 1-2 accumulator maybe 2 it will get violent on shifting....grind the second land from the back of the pressure regulator valve for the fulltime converter lube mod. thats about all you can do without cracking the case open and pulling it apart
is there anyway you can come up with a straight parts list and pn on the items needed for the 4l60e upgrades..im going to be running a 5.3l ls with a 4l60e 2wd truck trans..but in the future ill have cam intake and a .76mm turbo setup...looking around 600hp
