PT4000 vs. PT4400
Old Nov 25, 2003 | 12:21 AM
BADFNZ's Avatar
Default PT4000 vs. PT4400
I've searched and searched and found alot of info, I just want to verify some of it:
-PT4000 shift extension is 5300 vs. 5900 for PT4400
-PT4000 has around a 2.5 STR vs. 2.7 or so for PT4400 (varies)
-PT4400 feels a tad looser but not by much
-I read somewhere the PT4000 would be better from a roll because it's more efficient but that doesn't make sense to me because of the 4400's higher shift extension
-Not much difference between the 2 at the track
-Both use same internals
Now, can someone touch on all of these subjects?
Old Nov 25, 2003 | 12:45 AM
Colonel's Avatar
"-PT4000 shift extension is 5300 vs. 5900 for PT4400"
This is off a bit I think. Heck, my SS4000 has a 5350 SE but this is with a ~6600-6700 shift point which will have a small effect on SE. The PT4000 is surely better than that. I'd guess more like 5500.
2.2 STR compared to 2.5 STR according to Yank's site but I believe this is customizable to a degree.
The PT4400 would be better from a roll because of it's superior SE. 400 RPM of shift extension has alot more to do with it that 1% of efficiency.
Not much difference at the track? I guess it's according to what you consider a significant amount. I'd say they are within a half tenth at the track in an 11 second car.
Yeah, pretty much the same internals I believe.
Old Nov 25, 2003 | 12:51 AM
BADFNZ's Avatar
Thanks for the quick reply.
Old Nov 25, 2003 | 10:20 AM
CamaroCain's Avatar
correct me if i am wrong here, i am slowly starting to learn this stuff, but as for as SE goes, wouldnt that depend on the car itself and what mods have been done, like my car only being stock internal may have a SE of 5600 with the PT4400 but a H/C car would see the 5900 SE
FYI: 1.50 60' w/YPT4400 in my stock internal car at 3400+ raceweight
Old Nov 25, 2003 | 11:46 AM
Colonel's Avatar
Sure, like stall speed, it's going to be effected by the power made at the RPMs that we're talking about. In other words, if our SE is 5000 then the power made at 6100 is going to have much less to do with it than the power made at 5100.
Having said that, I don't think that SE is effected in a major way by heads/cam as much as it would be larger CI.
When I give an estimated SE, it's assuming stock CI.
Old Nov 25, 2003 | 11:52 AM
LS1 BU's Avatar
I get 5900 shift extension with my pt4400. I have heads and cam. I wish I could 60ft 1.50. Camaro Cain makes my car seem slow.
Old Nov 25, 2003 | 08:52 PM
Ragtop 99's Avatar
Shift extension is much closer. Don't expect more than about 300, maybe 400 rpm difference
That is pretty accurate. The 4000 may be a tad lower.
I have had both the 4000 and 4200 and they felt the same. Could not tell them apart.
The 4000 is more efficent. If you wind out 3rd gear in racing from a roll, I'd take the 4000's efficency over the 4400's shift extension. I went with the 4200 because from a roll it is more efficent than a 4400 and has nearly the same shift extension.
For Pure track use, I'd take the 4400. The extra stall and midrange should be worth at least .05.
Pretty much. I'm not sure if the 4000 uses the same pump with a blade angle adjustment or different pump.
Old Nov 25, 2003 | 10:20 PM
Hugger SS's Avatar
I drive my PT4200 everyday and love it..1.5 60fts on et streets with a full weight SS and 11.50 timeslips
Old Nov 26, 2003 | 08:43 AM
Patrick G's Avatar
LS1 Tech Administrator
The PT 4000 I had in my SS had crazy shift extension. Somewhere like 5800-5900. Never had a converter that was better from a roll.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Nov 26, 2003 | 05:42 PM
BADFNZ's Avatar
I did some comparisons on this theory and tell me if it makes sense. I said that the shift extension of the PT4000 was 5400 so I multipled my horsepower above 5400 by 1% (for the 1% increase in efficency over the 4400) and I came out with 379 rwhp at 5400 rpm.
If I take the horsepower of my engine at the PT4400's shift extension (5900) I end up with 390 rwhp. So with my calculations, the PT4400 would be better from a roll for me because my engine would never drop below 390 rwhp, as opposed to 378 rwhp w/ the PT4000. Is this an accurate measure?
Old Nov 28, 2003 | 06:19 PM
BADFNZ's Avatar
Make sense to anyone?
Old Nov 28, 2003 | 06:25 PM
CamaroCain's Avatar
Yeah that was on drag radials too What type of suspension setup are you running? Should have brought the car down to Thunder
Old Nov 28, 2003 | 06:27 PM
CamaroCain's Avatar
If you are that worried about it go in between with a 4200. I would go 4200 or 4400 and be done with it.
Old Nov 29, 2003 | 11:07 AM
Ragtop 99's Avatar
Efficency comes in after the converter has come off shift extension. I'm not sure where you got your numbers from, so I didn't understand your example.
Yank does not have a comparison of the 4000 and 4400 available but take a look at the SY 3500 & SY 4000 comparison as an example.
http://www.converter.cc/super_yank_dyno_overlay.htm
I think the YTP 4000 vs 4400 will be a little closer but as you can see the higher stall gives a little more pull in the upper midrange but the advantage disappears at ~4600 rpm before the shift extension ends (~4800) and from then on there is a couple percent advantage. This pattern will be similar on the 4000 vs 4400 but the curves shift to the right a bit since they have longer extensions.
Old Nov 29, 2003 | 11:32 AM
LS1 BU's Avatar
I didn't know that the Thunder race was on Sunday. I found out last minute. I couldn't see bring my car down for Fri and Sat only. My brother had to work on Monday so we couldn't stay for the race on Sunday. I run Hal coilovers on the front with moroso trick springs on the rear and a 50/50 drag shock. I also have a 1 and 3/8 rear sway bar in the rear. Front sway bar is off.
Old Nov 29, 2003 | 12:27 PM
BADFNZ's Avatar
According to the Yank website, it says efficency is calculated in the 5000-6000 rpm range where these converters spend most of their time. So basically I calculated the horsepower numbers from my car by the efficency percentage and took into account the shift extensions.
But screw it, I'll just go for a 4200 and be done with it
