What do YOU recommend?
Old Aug 29, 2009 | 02:45 PM
StreetSilverado's Avatar
Default What do YOU recommend?
Right now I have a Performabuilt 3600 9.5" converter with a 1.69 STR. It was set-up for my cam only set-up and it was perfect. I took my new set-up out last night and I couldn't get it to 60' for crap, the best was a 1.66 or so. I tried leaving at 1200 to 2100 and about 1800 was the best 60'. Anyway here is my new set-up and I'm looking for opinions on a new converter. I was looking at the SS4000 from Yank.
-370CI
-3600-3750lbs
-Moser 9" with 4.11's
-28" MT DR's
-470-515 RWHP EST.
I'll be spraying a 150-200 later down the road.
Old Aug 29, 2009 | 03:14 PM
Yank's Avatar
Sounds good to me!
Now lets hear from some SS4000 owners!
Old Aug 30, 2009 | 10:52 AM
Firehawk441's Avatar
You don't make enough HP to be using a 9.5" converter. You may want to consider dealing with a different company. Call a number of the leading manufactureres before you buy another.
Old Aug 30, 2009 | 11:15 AM
01ssreda4's Avatar
this is quite possibly the oddest post I have read in a while.
OP, call up dave at Yank and see what he says, obviously NA and Nitrous converters are going to be a little different, so see what he says based on your specific combo.
Old Aug 30, 2009 | 11:24 AM
StealthFormula's Avatar
After owning an SS3600 I would definetly recommend a Yank SS series converter to you and the SS4000 would be IMO the way to go. I would say go with a PT4000 or PT4400 but since you want to spray stick to the SS series.
Old Aug 30, 2009 | 11:32 AM
SSIRBY's Avatar
ss4000 is what i have. wouldnt spray no more than 150. i'm cam only but no numbers of any kind yet. will be shortly though.
Old Aug 30, 2009 | 12:07 PM
I have 28yrs of experience on torque converters and how to make a car 60'. Have a good day sir.
Old Aug 30, 2009 | 12:37 PM
stumprrp's Avatar
i have an ss3600 and although i have much less power then you all i could muster was a 1.69 on STOCK suspension, im sure there ss4000 is a killer converter for NA and spray, yank personally recommended me there PT4000 for NA
Old Aug 30, 2009 | 12:51 PM
The car was built to run the 7.0 index at the track, but we gapped the rings for it to be safe on a 150 shot.
I think I'll be sending it to PerformaBuilt to have it built to a 4000stall and 2.5STR. If not I'll be calling Yank and either going with the SS4000 or PT4000. I'm just a little stuck between since the car is really built for NA but if I want I can also spray it for the hell of it.
Old Aug 30, 2009 | 01:10 PM
bpowell688's Avatar
Hey blaine give me a call...
Old Aug 30, 2009 | 10:18 PM
01ssreda4's Avatar
please explain this further then, I'm all ears.
Old Aug 31, 2009 | 04:30 PM
01ssreda4's Avatar
waiting.....................
Old Aug 31, 2009 | 05:03 PM
TXZ28LS1's Avatar
i would definitely swap into the ss4000. also, do you have any suspension work done?
Old Aug 31, 2009 | 06:35 PM
salemetro's Avatar
I don't think that anyone here is questioning "credentials"....just curious as to what/why you would recommend, that's all. Seems that you would have some quite valuable input, other than simply "call around and see".
Old Aug 31, 2009 | 09:34 PM
I put a circle D 4c III in there today and it feels a ton better. I can get on it around 35mph and it just lights them 28" MT DR's up a good ways. Car has a few suspension mods
-QA1 Adj. shocks in all four
-Adj. LCA's
-Adj. Panhard bar
-BMR Extreme Torque Arm
and some little stuff I'm sure I'm missing.
