4l60e low roller cluch? limp mode? or?
Ok so i am having some weird issues..... i have a 2001 Chevy s10 with a 4l60e i just rebuilt with a new forward sprag and a rebuilt pump. When i have the truck on the lift and in Drive i hit all of the gears w/o any issues, then set it on the ground in Drive the truck acts like its barly in gear, little movement with WOT. My line presure does not change in any gear(limp mode?) 100psi no matter if 1 or reverse..... what am i missing here......and also what does the low reverse clutch do?? HELP ME PLEASE!!
LS1Tech Sponsor
The Low/Reverse clutch is only on in manual low one and reverse. If you are talking about measured in the port line presure i would say you have a massive internal leak or a stuck regular vave. Electronic limp mode etc would have no effect on reverse.
__________________
