Installing ES poly mount tomorrow
Old Nov 28, 2003 | 11:52 PM
Cheatin' Chad's Avatar
Default Installing ES poly mount tomorrow
What's the deal with "shaving the bumps"?
Any tips or tricks you guys used?
Any thing to watch out for?
thanks
Old Nov 29, 2003 | 08:37 AM
WILWAXU's Avatar
I just used a bench grinder, it does help.
Pretty straight forward.. just grind off the little bumps.
Old Nov 29, 2003 | 08:40 AM
Well,that's what I'll do then.
I appreciate the prompt response!
Old Nov 29, 2003 | 10:39 AM
flyinZ's Avatar
what about taking out the preload plate??? I heard that helps too.
Old Nov 29, 2003 | 01:32 PM
WILWAXU's Avatar
I run the preload plate.. but after you remove the bumps.. it's just a plate/spacer
Old Nov 29, 2003 | 01:51 PM
foff667's Avatar
LS1TECH Sponsor
i didnt do either and i dont have any noticable vibrations...
lata
BIll
Old Nov 29, 2003 | 05:01 PM
Ok so I ground off the preload bumps with a bench grinder (worked great)and used the plate. Had to jockey the crossmember a bit to get things to line up. Works great. No more exhaust rattling. Cars seems more firm all around and the additional vibration is hardly noticeable. Matter of fact it doesn't bother me AT ALL.
Good deal in my opinion.
Thanks for all the help!!
