opinions on using a PT4400 with nitrous
Old Dec 1, 2003 | 05:54 PM
Gold Z's Avatar
Default opinions on using a PT4400 with nitrous
I would like your opinion on using a PT4400 with a 100 to 150 shot of nitrous. The car is a 99 Z28 making about 400 rwhp. It has 3:23 rear gears. I know it isn't anywhere near being a nitrous converter but it's the convertor he has.
Old Dec 1, 2003 | 06:50 PM
BADFNZ's Avatar
I would think it'd have too much shift extension and be too loose for N2O, but I'm no expert. I'm sure one of the pros can give you a real answer.
Old Dec 1, 2003 | 08:10 PM
Ragtop 99's Avatar
The YTP 4400 isn't ideal for a 150 shot. If he had 4.10s and a high revving cam (6800+ rpm shift) it would probably be ok.
In his case, it is bad combo. The 3.23s are too short gearing wise. Since he has the converter, go ahead and spray and see what happens.
Old Dec 2, 2003 | 12:24 PM
02redSS's Avatar
it wont cause any damage right? just probably wouldn't run optimum? or could it cause damage to the converter?
Old Dec 2, 2003 | 03:29 PM
Colonel's Avatar
It's not going to hurt anything but it will make a 150 shot more like a 100-125 shot as far as the ET is concerned.
Old Dec 2, 2003 | 08:46 PM
Gold Z's Avatar
Thanks for the opinions. All are appreciated. Anybody else have any thoughts on the subject?
Old Dec 11, 2003 | 10:45 PM
Haaseman's Avatar
Oh just spray it
Old Dec 11, 2003 | 11:02 PM
onebadz's Avatar
Yea man I would say go ahead and spray it if you already have the verter, if not then look at yanks nitrous/FI verters, you cant beat em. Good Luck
Wes
Old Dec 12, 2003 | 01:12 AM
Elite_Hot_Rod's Avatar
With that converter your gonna have way to much shift extension for the bottle, your ET's will be down and unless your on 28" or bigger drag slicks your 60' won't be good either. 3800 to 4000 stall at the most on the hose.
